Boiler is in the garage at the moment - having moved it from the kitchen to gain extra cupboard space when we extended (kitchen only has one external wall on the short end with the window - so no space there anyway now).Do you really not have enough wall space for a boiler to hang on. They can be smaller than standard upper kitchen cupboards now.
If you're thinking of going for a combi then can't you stick it in the airing cupboard, assuming you have one.?
Why would you need an external flue, either fit an internal one to a better location (within distance constraints) or fit an angled outlet to direct the gasses differently so there is enough space.
Combi, not a fan, to much extra to go wrong, condensers are bad enough in the first place - also need a big one to be able to run a bath and support taps/showers.
We might just get away with an angled flue (i.e. 45 degrees), but height might be an issue as the boiler is mounted quite low on the wall due to an RSJ above it (wasn't prepared to loose 6in of garage to a double skinned wall downstairs when we built the extension) hence the possibility of an external flue to raise it up. Can't remember at the moment if there is a min height for a condensing flue outlet which discharges across a pathway. A read flue would probably come out at 1.8m above the path, with a side flue we could probly get it tight against the RSJ could probably get 2m.
A Keston boiler is one option on my list as they use 50mm plastic waste pipes as a flue with separate in and out pipes gives much more flexibility.
