I have a w124 and had the engine rebuilt. I was later told that the mechanic replaced the old engine block with a new one. However, the new one is not especially made for my model car.
The car has driven 15,000 miles since rebuilt and it still drives very well! It always starts first time, no white & black smoke, stable at idle, everything works as it should!
But I do have some issues which maybe serious.......
(i) The oil pressure looks quite low. After the engine has warmed up, the oil pressure goes down to 1.2. Sometimes it is slightly under 2. But when I press the gas, it peaks to 3
(ii) It seems that there is some oil residue around the head gasket. Is it possible for coolant to mix with engine oil on w124s? Engine cap is clean, coolant reservoir is clean and engine oil is clean as well.
I hope you can give me some help.
Thanks!
Thanks!
