fwd
Hi... would appreciate a bit of advice...
Would a failing lift pump (bolted to the side of the inline injector pump) cause masses of air to be present in the system as seen in ALL the plastic lines ?
I have changed all the o rings on the pipes, pre-filter and shut-off solenoid, even bypassed the fuel tank with a make-do gravity feed and return, elliminated/bypassed the fuel heater to no avail
Any idea how much these pumps cost and is it a MB item or can it be bought from elsewhere ?
Thanks in anticipation...
