bobtailbun
- Nov 21, 2005
Newbie, hello to all. My first post -
1984 280E, started as usual first time. Warmed up and then stopped dead along street. Seems to be fuel to system, no spark at plug. I have followed MB manual and checked ignition system with meter (breakerless/no resistors), apart from dwell -which I can't check. -
the symptoms point to the ignition distributor. I would have guessed at the ECU, but the fault chart says, distributor.
Is the only remedy replacement? Has anyone else had this problem/what cure?
thanks , Bob.
thanks , Bob.
