C207 . 2017 . Have you updated the icarsofts software recently. ?Is that on a W213 though?
I have updated the software and it seems to work with the C207 but not W213 for some reason.C207 . 2017 . Have you updated the icarsofts software recently. ?
I wish I had a star system but live in hope that through time Icarsoft will support many more functions for the W213.As good as icarsoft are., they don't suppport every test/function on every vehicle. If I need to view DPF data on my W209 OM646 I have to use my Star system as icarsoft doesn't support it.
Pick any car with the same engine with dpf basically.So if I select W212 instead of W213 I might get live data for DPF?
That will not work and you risk corrupting the data on the card.If anyone wants to try another SD card in their unit with my mb3 data on it , I'll gladly send them it . I've always wondered if it would work.
Nothing lost then. Have you tried doing it ?That will not work and you risk corrupting the data on the card.
As long as you save the original files to a laptop ,nothing gets corrupted or lost . Using a totally separate sd card to the original is the way forward. I'd think the only thing stopping this is the seriel number of the unit itself . ??No. But I did try to upgrade my earlier icarsoft to a later version using the online updater. The result was total meltdown and locked me out when I tried to go back to the original files. fortunately I had backed them up.
