Yes, the top plug that you're holding in the pic is almost certainly a CD changer. There's also a bluey-purple thick double cable down there that looks like it used to belong to an amplifier (probably fitted under a seat or in the boot). If it's that it will have 'phono' plugs on the ends of each of its cables, which would have been plugged into the radio at some point.
HTH,
Ian.
