Offset different for CLS 55 and E55?
MOR8A
Sussex
W212 E63 PPP AMG
Hi
Is there a difference between the wheel offset on C219 CLS55 and W211 E55?
Thinking of putting on the 19 inch solid 5 spoke CLS55 rim onto an E55 and wanted to check to see if they were the same or if not does it make any difference or are there any problems that you are aware of in making this mod? Also thinking of the R230 SL65 wheels, same quetion applies.
Many thanks.
Another member put CLS rims on his 211 E55 and it looked great, the offsets are different, it gives it a fatter stance... As for SL rims, I know they fit the E and CLK as I had a set of SL rims on my previous CLK
Hi and thanks for your reply. Do you know the member that fitted the CLS rims to his car? Do you know if there were any issues (guessing not) I would like to be able to contact him.
member e55 has got 19" cls rims on.... all cls rims will fit CL rims wont!
No I think mine are 19 inch SL rims. Its bishy that has the CLS rims on his car. But hes sold the car now so not sure if he visits here anymore.
i stand corrected :)
cls rims will fit straight on though
Without issue? Same wheel bolts? Nothing to be done at all? Do you know if they would rub if the car was lowered? I think that the offset may bring them out a bit and therefore may rub the arches????
Thanks.
The 19" 2piece CLS wheels are not TUV approved for a W211. Thats not to say they wont fit. But most AMG wheels are available in more suitable fitments in the same design.
Thanks.
depends if your going to lower it i guess, the US forum guys have all done it without issue, pop onto mbworld and have a look, many e55`s modded on there!
Those are available in a r230 fitment, which would be better suited to your car. However, from the posts above it seems they should fit.
Thanks aka$k. I have pm'd you.
