Oil filter on 124
marcintosh
Sheffield
E200 W124
Do I need to get this special tool from MB to undo my filter or is there another, low-tech (and low-cost) solution?
depends on what sort of engine you have. Is it a M111 or a M103? 4 cyl or 6 cyl?
I think you mean a 76 mm 14-flute cap socket. They're not expensive and available from Motor Factors, 'Hellfrauds' etc.
if its a canister type of filter at the back of the engine then a screwdriver hammered through it is enough to slacken it for removal. If the filter is at the front of the engine and covered with a plastic cap then yes you will need the 76mm socket as posted above.
Or one of those things old people use to open jars...works a treat!
It's a 2 ltr 2 cam unit. I asked at Halfords but all that they had was a self-tightening wrench and it looked like it would crush the plastic housing.
I have a belt oil filter wrench, similar to the chain one but there isn't enough space between the inlet manifolds and steering pump to use it. You can only access it from above. Will ask about that socket...
I bought a oil filter large socket from MB some time ago partno W1035890209 00 works fine. If your car dealer denies all knowledge try MERCEDES COMMERCIALS.
Checked with MB. It costs 13 pounds. Not too bad.
