Oil in the footwell passenger side
Yes mine does have air con. It works perfectly are you having problems?
No im not but if the air con has developed a leak on the evaporator on your car then this could be the reason for oil to be leaking from the air con system and leaking onto your passenger side footwell.
common fault and yes the oil will be pushed up the loom from the pilot bush to foot-well
well known fault
as is the same in a c230 kompressor the if the breather is blocked it will bush oil up the loom to ecu you can get a kit to stop this
it happens at the engine to ecu
Is there any way you can tell if there is drains plug on toruqe converter on my car? As i will be changing the gearbox oil next week
Finally got the gearbox oil changed today the car is really smooth now am really happy with it
:thumb: :thumb:
