Hi I can't find how to check the oil level through the dash on my c63 58 plate ,and the deep stick as 2 marks , can anyone give me a hand with this?
Thanks in advance!
Use the dipstick - top mark is max and bottom is min. 1.5 litres is the difference between the two, as I recall. I don't think there is an indicator on the dash, other than a message to ask you to top up.
so in the deep stick you have a plastic bit at the end and then metal and again a plastic bit and metal again and a as tic bit at the end !
So I use the upper part of it??
