rf065
- Jun 8, 2007
- Location
- Grossbritannien
- SLC300 - C250d Estate 4 Matic & Z900rs
it sucked the oil from the sump and blew it through the injectors
How is that possible?
Russ
Sometimes there is no way and engine blows up .Just out of interest when "engine was running flat out" with out keys how did you manage to stop it running?
I ripped the airbox of and jammed my hat over the intake,thankfully it stopped (I was well outa the way,I didn't fancy a con rod in the face)Just out of interest when "engine was running flat out" with out keys how did you manage to stop it running?
The bearing in the turbo fails then the oil seal fails,the pressure sucks the oil (that's used to lube the turbo)past the blown seal and it's forced into the intake,the engine then runs on its own sump oil,the throttle is now redundant,you have to act quick,either try and stall the motor or stop the air feed,terrifying(well I thought so)How is that possible?
Russ
Do some people never actually read previous replies before posting?
Just wondering what if it happened on a auto?
The only way to stop such a runaway engine is to cut off its air supply. Open bonnet and hand / lump of rag over the engine air filter intake.when i stated the engine will pick up, if the oil level rises to far, it will get picked up by the pistons, then the engine will run on its own with no way to stop it until it destroys itself. I have seen it happen, its a very frightening experience.
You could have a sample of the oil tested for approx. £25-£50. Amongst other things it would quantify the extent of fuel dilution.
Bit hard to get that done as Greenflag managed to crack my sump somehow on the journey home. Had another sump fitted at my expense and had all the injectors out and they werent all blacked up and it i'snt smoking anymore and covering everywhere in clouds of white smoke. Garages have no idea and not managed any real help via the forums.
I have seen this reported many times with 'remapped' DPF. Sometimes programming just goes wrong and car tries regenerate non-existing filter.
It has had the dpf mapped out but just seems strange that it did 3k before it started blowing smoke at low speeds and then smoke stopped when back at 50mph plus
Yep its not unheard that some mysterious combination of engine data readings triggers DPF regen even it has coded out. I remember couple of case with very first DPFs and map first programmers (I believe they have learnt slightly better how to prevent regen). Why it stops at 50+ I acnnot say IF it is not related to different regen 'states', it is just hearsay but I also believe there are different regen parameters depending are you driving full blast on highway or sitting on idle in traffic lights.
If you can confirm your injectors are solid, and oil addition is fuel, cylinder compression ok, it is almost only possibility. I wonder if SDS would give info if regen in on. I never seen it how it looks like as a live data, only forced regen.
