Durtlocker
Hi guys i have a component which i have broken in the dismantling of my head on my 2001 v-class.This component is a sensor which is housed within one of the alloy brackets which hold on the fuel rail to the cylinder block this block also passes fuel through it from the banjo on the end of the fuel rail then out to the filter head which i believe is the fuel return pipework in this alluminium bracket is positioned a sensor with two wires and two pins ,this sensor is what i require a name and part number for please if anyone can help this would be gratey appreciated
