W1ghty
Hell yes !Your main orange turbo seal should really be pushed in more than that btw!
Update your car details from Honda civic buddyThat's an awesome video. Mr Greedy thanks for the list of parts. Makes life much easier.
I have a load of oil all over my aux belt and I'm almost certain it's from where the metal pipe joins the black resonator.
Might even attempt my self.
I do have a small crack in the bat wing... How worried should I be? I was thinking of using some plastic weld or araldite.
The large orange seal should sit into the plastic intake ‘batwing’ pipe like this. If you can clean off all the old oil from the crack then araldite might work. Worth a go as the pipe is pretty expensive View attachment 122431
That's really useful I'll probably get my mechanic to change it tbh.I had a leak on the intercooler hose that comes out of the resonator and feeds into the intercooler. I changed the seals on both ends. It’s close to the location you mention, so check it out of you can!
That black seal at the end of the silver tube can be tricky as it doesn’t always give you a confidence inspiring pop or feeling that it’s correctly in place. I’d change all the seals you have the ability to change!
That crack in the batwing doesn’t look small to me. I’d Google turbozentrum and buy a silicone hose and dremel off the rest of your hose, or buy a second hand one perhaps? It’s such a silly design…
Yeah the design is a little silly if I'm being honest. Seems a bit trail and error getting the right tightness Vs it cracking off.I will say that even if you really tighten the clamp down, it won't stay like this for long, it wants to slip away. And if you oven tighten it, you risk cracking it, especially if it's an older car.
Which is why I feel like it's simply best to swap it out for a new one and re-tighten every 6-12 months, especially on my car which has a crack in each of the 'nipple' holes, so eventually cuts into the rubber nipple on the orange seal.
By the way, it's worth doing this yourself as MB Epsom charged my (elderly) dad ~£170 to change this seal on the service before last. The recent service just a month ago, they didn't even mention it even though it looks like J19YTP's at the moment and is visibly weeping a bit. They also left one of the airbuses unclipped (??) and broke one of the plastic holders off the engine cover, plus a few other bizarre things. I told him not to drive it until I sorted it for him...
You're a legend sir. Thank youI'm at a computer now so I can give you the link of the one I purchased: Repair Kit Intake Mercedes Benz CDI OM642 (blue), £ 24.23 (you can also get black)
At the time I didn't realise you had to dremel the original batwing, and mine isn't as bad as yours. From what I can see you have very little to lose!
I pretty scared about hitting it with the Dremel but you're right very little to lose.I'm at a computer now so I can give you the link of the one I purchased: Repair Kit Intake Mercedes Benz CDI OM642 (blue), £ 24.23 (you can also get black)
Interesting. I had it refilled a few months back and he did a leak test, so I'm hoping its not.Rad fan might be no air con gas pressure.
Thread here:
Post in thread 'C350CDI engine fan comes on straightaway' C350CDI engine fan comes on straightaway | Parts, Maintenance & Servicing
That seems like a good deal at £38 (sorry for being nosey). Is that from MB Grangemouth?Today’s OM642 annual goodie bag
These parts are generally cheaper direct than via eBay
