Afternoon all,
My 2008 E220CDi seems to have air in the low pressure diesel pipework near the fuel filter. When I turn the ignition on you can hear a lot of air bubbles rushing through the pipework for about 20 seconds, presumably as the lift pump in the tank operates. I suspect that air is being drawn into the T-piece that joins the injector leak off pipework to the fuel filter pipework as that's where the noise is loudest. If I "stethoscope" it with a length of plastic tube it does sound like air is leaking into that joint.
The car starts and runs OK but if there is a problem here I'd rather sort it now rather than break down somewhere inconvenient.
Can anyone confirm that there should be no air in this pipework and if the T-piece is known for letting in air? It seems to be assembled from two parts clipped together so it may have some o-rings that I could replace.
