One highbeam not working
babz
Newcastle Upon Tyne
1996 Mercedes C180
Hi guys, noticed last night my passenger side high beam isn't working on my 202, checked this morning and bulb seems to be fine, as are the fuses and also the wiring. I don't have any fancy equipment to see if they bulb is receiving any power or anything so is there any other ways I can resolve the issue?
Thanks in advance!
I had exactly the same problem and thought it was the bulb but wasn't. I then thought it must be a bit of corrosion so slid the connector on and of the bulb about six times after spraying with wd40 and hay presto it was working again. Sometimes the bulb looks ok but without having testing equipment you can't be sure. Try the bulb in the other side and see what happens. Cheers, Tony.
thanks gents, ill be giving this a try later on before it gets dark. ill let you know how i get on.
