Contrary to popular belief, diagnostics equipment, however complex,isn't a guaranteed diagnosis and repair,mostly it only indicates,or guides you in a certain direction. An indicated sensor fault can be a wiring fault, or a symptom of another sensor fault somewhere else, this is down to the mechanic.
I completely agree with this one, I've seen things missed by Bosch Diagnostics and dealer diagnostics that Have been picked up by Snap On Diagnostics. To be fair some of the dealer diagnostics are only as good as the technician using it would rather put my trust in an Indie that knows the marque in depth rather than an inexperienced technician at a stealer who will normally just keep changing parts until the fault is cured
Totally agree, but in this case the customer was immediately sent to the dealer on his return, without further investigation. Although well intended, the perception this creates is that the mechanic is not confident enough to proceed further, which would understandably negate any faith the customer may have had in the first instance. Although hindsight (and more importantly, the dealership) revealed the first diagnosis to be correct, the the mechanic didn't stand by it, so (again) it creates the impression of dabbling. Perception is the customer's problem here, which is why I said earlier, some jobs perhaps shouldn't be taken on in the first place if they knowingly can't be followed through to a satisfactory conclusion.
The manufacturer gets away lightly in these circumstances, as they are not liable for labour incurred whilst fitting faulty parts.
The best question of all is for the customer to question the main dealer why his bill is so expensive for the same job !
