campbellju
Hello everyone,
I've been following the forum for quite a few months now since recently purchasing my first mercedes, a W208 430CLK. I haven't posted before as being an existing car nut and regular forum user I've found the search function to be so good there's not been a reason to post.
The rubber seal on the passenger side has appeared to drop so that when the door closes, the rubber gets trapped behing the glass causing wind noise. This can be solved by winding down and up the window but I would like to find a more premenant solution.
I've found one similar post with no answers but at least I know its not uncommon for mercedes:
http://www.mbclub.co.uk/forums/showthread.php?t=12420&highlight=door+rubber+seal
I have tried pushing and shoving but to no avail. I am not sure how to completely remove and refit the rubber which might be worth a shot and my final option it to attack the rubber with either a soldering iron or a knife but this is obviously a last resort.
Any thoughts or advice gratefully accepted.
Cheers,
Jim
Cheers,
Jim
