PAUL R
- Mar 20, 2005
- Location
- South Staffordshire
- Golf SV GT,Polo SEL (gone) ML270 CDI (gone)SLK230 (gone)
Hi Guys and Guyesses,
Could anybodytell me, Do PC case cooling fans force air into a PC case or extract air from the PC case?
I have a mother board monitoring system that tells me the zone temperatures ,and each has a limited threshold before it alarms.
It appears that the temperatures are always near there mid point range 55to60 degrees.
Is this normal?
i.e. green go's up to 50 degrees, yellow go's up to 70 degrees,and red thereafter.(The threshold is 70 degrees).This is the Processer zone.
The other two areas, 1 and 2, run at about 10 degrees lower,45to50 degrees,(the threshold here is 60 degrees)these are zone areas in the case.
Is this normal?
At the moment they are all forcing air into the case,exept one which is a extractor fan which is situated in the back of the case (like a plug and play grapics card/dial up modem).(the one fan at the side of the case sounds as though it is surging),
Or should i reverse the fans?
There is plenty of space around the case for air to travel(exterior), and there are the natural vents that are built into the case,But i think that the PC is running too hot, As i was talking to a man in PC world and he said case temperatures are around 26 degrees.
Any advice would be welcomed
Is this normal?
Is this normal?
