Hey guys, I know this a product and method that many of you don't believe works, Most of you also know that I'm a big fan of BH Autofoam for its cleaning power, but the downside s that it's very thin and doesn't give you much working time to do other areas while it's working, and some worry about hi PH levels not being LSP safe.
Well here is a brand new product brand to the market that has been developed over the lastv2 years by a detailing company called Detail Driven. They are a specialist in car detailing and Modesta coatings.
The Foam is PH Neutral, with a good swell time and a decent amount of foam. It rinses of the panel very well, and cleans extremely wellIve tested this myself against BH Autofaom at the same PIR.
I mixed 200mls of product to 300mls of water giving g me a PIR of 2.5%. Coated the car and left to dwell for a good 15mins before it started to dry.
As you can clearly see from the pics, then foam actually removed 95% of the soiling from the paintwork, the car hadn't been cleaned for 2 weeks and only had a small amount of protection left from the wowos Crystal sealant that applied 6months ago.
I also tried this on the wheels, and again also removed the majority of the brake dust and grime
Next time I have the faom I'll try it half the dilution rate tob1.25%PIR to see how it performs
The Foam cannon is also made and supplied by Detail Driven, it's a wide next bottle, and quite short, it still holds a litre of water and is very sturdy meaning it doesn't topple over like my AB lance.
The Full product range goes live on the 16th November with a full line up of detailing products, towels, mitts etc etc and shall update you with the link to the site then
In the meantime if you want to try these products contact detail driven Detail Driven.
