- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
We use the above for our central heating and hot water.
It's never given a moment of trouble, and I don't want to spoil the trend.
Like half of the country, we've just experienced a freeze-up and burst to an outside pipe.
It only supplies the outside tap at the back of the house, so I've done a temporary fix by bending the 15mm copper pipe back on itself and hammering it flat.
To do a more-permanent fix, I need to turn off the water to re-position the tap inside the back porch.
When I turn off the water and disconnect the burst pipe section, are there any precautions I need to take re the combi boiler ?
Obviously, I won't be turning on the hot water taps, while the water supply is off.
All the connection pipes to the boiler come from above.
So there is no chance of the water draining away from the boiler when I have the feed to the outside tap disconected.
Can I leave the central heating running without a water supply attached ?
Are there any other dos and don'ts ?
Any advice will be warmly appreciated.
