Possable blocked breather
ricky300ce
essex
300ce-24v,clk 230 komp
I don't know ?? I have condensation & water coming from camshaft cover breather to air filter, could this be a blocked breather somewhere ? I have 1990
300ce thanks
Sounds like the breather pipes are working as they should.
Does the engine use much water?
Is the car not used alot?
Yeah it's not used a lot have no water loss thanks
That's just lack of use causing that, it wont be a problem till you get condensation in the dizzy cap.
Thanks as always you helped me out again cheers
