Jim55
I'm doing a Diy install of reverse camera and stand alone monitor( as I don't have the command unit which can display the image ), I've installed the camera but not connected yet just ran the wires through and fitted the actual camera so there's no power to it yet , it's just there in the right place ,
Now where is the best place. To take a power feed from for the camera ( actual reverse light wiring , and an appropriate earth ?
The monitor needs a power feed to , where is best for hard wiring this ( I'm not plugging it into cigarette lighter , is it run a feed along from rear Sam ( behind trim in boot and run along to monitor ,and if so is there a certain point on Sam to connect to) or is there somewhere better nearer front ( where monitor is going)
Jim
Jim
