Boristheblade
I've only had my 2012 E63 AMG prefacelift a few months now, initially everything worked perfectly.
The car has just over 50k with full Mercedes service history.
I couldn't see anywhere that the gearbox had been serviced (oil & filter change) so I had this done at a local gearbox specialist do this.
I also had the rear diff oil changed about a week later.
Only about a week later the outside temperature dropped significantly and the car juddered to set off in 'C' 2nd gear, this was obviously due to the new 'thicker' oil that had been put in the box.
This does not do this in 'D1' or S
Apart from that, the gearbox changed fine, both up and down.
The gearbox place told me the oil had not been changed, as it still had the original Mercedes filter in, he also said the kit he supplied was an updated one, which came with a revised overflow tube that allowed a little more oil to be added to the box on refill.
Onto a few hundred miles later.
The gearxox does some very strange things, sometimes it changes very smooth, sometimes lumpy.
Occasionally when coming to a junction, if the junction is clear and you can go without fully stopping but have slowed down, its almost as if the gearbox doesn't know what to do.
Now when driving the revs are flairing about 200rpm (not all the time), this seems to happen more just before the gearbox changes down (just before a hill etc).
However I have seen it do it on the flat.
When it starts to flair/slip, if you give it more acceleration, it just carries on as normal, no slip or loss of power.
I've done the transmission adaptive shifting reset via the accelerator pedal, but I only did this yesterday, I doubt this will have any effect anyway.
From what I've read, you need to drive it in 'S' for the car to TCU to relearn?
From what I've read it could be a multitude of things:
You are being redirected...
Needs a software update and the adaptations resetting.
Possible star clutch has started to slip.
Conducterplate/ valve body.
I know ultimately I'll have to get this in somewhere and get it looked at, but any help, advice, information would be greatly appreciated.
