I have just had a pressure warning for my rear near side tyre so I stopped at the garage to check the pressure but as I removed he dust cap the valve sheared leaving the top part in he cap.
I could get a replacement valve fitted or get Merc to sort the problem out. My only question is where does the pressure sensor reside in the valve or is it calculated by the electronics? I am assuming it valve related as the dash gives a psi reading. I should hive it back to Merc as I see this as a warranty issue but a its my daily commute a quick fix is preferable.
I
I
