Hello and happy xmas to everyone.
My car has developed a problem recently and it is as follows.
When I am driving and then try to accelerate the car sometimes just fails to respond like a throttle blip and ricks your neck and like someone has turned off the ignition , if you take foot off pedal the try to accelerate again it does it again this happens about 3 times them it will kick in and all ok. This problem is not every time and happens when hot or cold.
Also sometimes when I'm cruising at say 70mph the ESP light will just start to flash constantly and if I press throttle no power just like if your wheels are trying to spin. If I drop down a gear then all ok or if I release all throttle and the reapply it clears and drives ok.
Not sure if these two problems linked but I would imagine they are. I have put car on a basic fault reader and no faults.
Does anyone have any idea before I spend money on a star dianostic check.
