My Mum's 211 flagged up the bulb failure message for front right indicator lamp.
On wriggling the light fitting around in the socket, the bulb came on so it's a dodgy connection.
I pulled the lamp socket out, and sure enough, one of the contacts is all black and dirty.
So I replaced with a new lamp holder but now the bulb wont come on no matter how much wriggling I do.
I've ended up putting kitchen foil over the connector on the lamp fitting and then screwed it back into place.
Voila, the lamp works.
So it seems the electrical contact in the headlight unit is all corroded.
Anyone come across this?
Think I'm gonna need the whole headlamp unit out to clean the contacts properly, but is this easy enough? Car has xenons.
Thanks for any help.
