Pse
mark.t
Banned
manchester
E300 td tomtom sat nav in car dvd
its broken:mad: new from merc £465 inc vat :eek: :eek: ...... sourced second hand one £100 quid :( .... fitted and all working :) bloody expensive so if you went to merc ..... i bet ...it's one hour £90 to look + one to fit so that would be £645 please ...and help yourself to a brew :crazy:
If the motor has failed you cant fix them,if the fault is on the PCB, all of the components are replaceable
stripped the lot down ..... the pump rota arm had broken into little bits on the thin end of the cam which turns the pump .....so my guess is the pcb is ok ...... will keep it and look for a replacement pump?????.
just noticed somthing on the old pump it started making a double closing sound before it went wrong ..... but it worked like that for a good 12 months before it packed up .......the new one suts the locks rapid and with one solid thump sound and opens the same
