What do I have to do on the PC so that it behaves like the laptop?
Pour petrol on the PC & Router
Add a lit match
Step back and feel the warmth of this whole community
Ha ha ha, I did it so many times on my laptop and PC plugging in a ps2 keyboard after it booted and it still OK after 8 years.![]()
Add a lit match
Step back and feel the warmth of this whole community![]()
Laptops are designed for portability, designed so that you can suspend, sling it in your bag, drive to work and power up and attach your peripherals without needing a restart.
PC's are simply not designed to do this. The Bios will often error out if it cant see a keyboard and mouse at startup.
Its possible your bios does support this option on your desktop but frankly if your machine is using ps2 its likely to be so old that the bios wont support it.
Your post also begs the question - why do you need to do this? Are you sharing keyboards between multiple PC's or something?
As others have said, if you want to do this just buy a USB keyboard. £10...
Shutup, another irritant.
You are worse than the Yorkshire terrier!
Are you referring to me? if so I'd appreciate an apology as this is insulting.
If not then just who are you referring to?
Once the machine have booted with the keyboard connected swapping generally seems OK, used to do quite a bit as a manual KVM (many years ago). Now I just use VNC/remote desktop.i have plugged mice keyboard back in when live and havent fried anything yet... our work one always seems to fall out!
NB I fixed the power supply shorted the 12V output. Have to use the hacksaw to carefully prised open the plastic box and glued it back with super glue. As for the laptop keyboard, liquid had been spilled on the keyboard control chip on the system board. Have to disable the keyboard and touchpad and use an external keyboard and mouse. That where I noted the difference between the laptop and PC hot swapped of PS2 devices.![]()
[Yorkshire accent]PS/2 that's new fangled stuff that is lad[/Yorkshire accent]. This very keyboard I'm typing on has a full size din connector (plugged into a PS/2 adaptor) and an AT/XT switch on the back.Is it only me old enough to remeber PS/2?![]()
Well we 'ad it tough.
Used to get up 'arf hour before we went to bed, AND pay t' mill owner for permission to work.
