Pyro fuse location C205 URGENT HELP!
mercedes23
North Yorkshire
c220d
Does anyone know where the Pyro Fuse is located on a 2016 C class coupe?
I've searched high and low around the battery and can't see anything remotely looking like it. I notice quite a few people have asked this question on this forum which has gone unanswered. Please help! So I can start my car! Thank you kind people!
Hi Grober, I can't see the pyro fuse on the data sheet url you've pasted.
Scroll down to the second diagram. Its fuse #301 5amp.
The fuse box is in the passenger footwell.
The diagram is for LHD models so may be confusing to begin with.
So it's not near the battery? Surely it will have the airbag sensor / plug?
I called Mercedes today they stated it was located near the battery and gave a part number of: N0006967
which looks like this. really confused?
PS. This says for a hybrid, mines not a hybrid its a C220d coupe.
301Hybrid: Pyrofuse via high-voltage disconnect device
^ Apologies, didn't notice that.
So its not listed in any fuses in those diagrams?
Not that I can see. Mercedes stated that their diagram didn't show where it is exactly besides from an arrow under the bonnet??
Do you have Mobilo cover? If you had a main dealer service within the last 12 months you have.
That is the only solution I can think of to get a tech out to replace the fuse if you can't start it.
Its saying passenger footwell
I called Mercedes and they told me that it is this type pyro fuse, but I can't see it anywhere. can you? Kindly reference to my pictures
Do you have any dash light coming on when you switch the ignition on? Is the car completely dead, or just doesn’t crank?
Why has the PYROFUSE BLOWN? Has the car been in an accident, or are you rebuilding it? If its been sat around a while parts may have been removed!
Is it an ECO stop start model as some of them don't list a pyrofuse in the forward fusible links assembly. This may be due to 2 power sources available to start the car so an alternative arrangement may be required?
The airbags have blown. No parts have been removed. Not sure on eco stop start will have to check that.
I've read numerous threads asking the same question. Where is the pyro fuse on the W205 all threads have gone unanswered.
Baffling as this must be a very common / basic question
