R107 standard wheel bolt size
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
Hi
my R107 SL i've just bought has a series of different bolts on the alloy wheels. There are a mixture of differnt sized heads and lengths of thread in them and some are really stuck in and some are easy to come out. some i assume are meant for steel wheels, others for later mercs :(
so, to cut a long story short, i need a full set of new bolts (x50)
I've checked Mercedes who are priced at £50 for the set.
There are plenty of cheaper alternatives on eBay but i need to know the spec of the correct bolts before ordering.
can anyone give me the spec/thread size etc etc of the original R107 SL wheel bolts in 1985 and this is for the Mexican Hat style alloy wheel.
also of course if anyone knows of a good cheaper supplier then i'd be interested to know :)
thanks in advance!!
derek
PM sent :)
Will
Some pictures would be nice.:)
And by the way, great colour.
get them from alloy wheels direct. they are standard mercedes size... dont get the ones with the extended shank... they look good but can break...
i've ordered 1 bolt from Mercedes. I only have 4 suspect bolts - all the rest are the same so i assume they are the correct ones. i've ordered 1 bolt to compare.
otherwise i'll check out alloywheelsdirect. I was told 107 and 129 cars use different alloy wheel bolts than later mercs, so are the ones on alloywheelsdirect correct?
update - new correct bolt ordered from MB and confirmed that its very similar (but not identical) to majority of my existing bolts - so all i need is 4 new bolts rather than replace the whole lot.
