R129 1994 Suspension
Watchcame430
Previous 1994 SL500, 2001 W210 E430 and 2003 Designo S500 Current 2005 S211 E270
Mercedes discovered a passenger side broken spring today when I was having some other work done.
Seems like a good opportunity to change the whole lot.
Anyone got any suggestions or advice?
I am planning on replacing with original equipment but didn't want to miss out on anything better.
Not into the whole lowering thing! :) thanks
Replace with original springs is your best option.
Thanks ... Will do that. Guessing a Mercedes direct part only?
I have read they were fitted with a mix of sachs and Bilstein struts ... Would anyone know if the non Mercedes marked parts made by these two companies are identical?
Happy to buy from Mercedes as I like original equipment but I know sometimes they are literally the same.
I have some original springs front and back for my 500 left over from when I lowered mine.
Take them away, I need the space.
Thanks Sp!ke, really good of you... Would be a good fix while I gather all the bits to replace with new and I might need the cash for the roof if its the controller in the meantime so might be needed longer than I think!
Pm on its way :)
