Russf123
Guys,
my '97 SL500 is starting to run a little hot in traffic. She is fine on a run but as soon as stop/start running is involved, she starts to creep up to 90 degrees. So, have flushed out the coolant and changed with MB spec and changed the thermostat. I have noticed that the large, engine side fan seems to run all the time and that the 2 aux fans dont seem to be cutting in. At what temp should the aux fans cut in and is there a adjustable temperature cut in on these and is there anything else I can check?
Russ
Russ
