R129 window motor wires
rocketfixer
Bucks
E220 estate 2007/ Sl500 R129, 2000
I,m still messing with my auto drop problem. Windows work ok from switches but does not drop when door or roof operated. I have resynced and can hear a click after about 5 seconds ( same click if syncing left or right side... so I figure this is ok. I have checked door latch microswitch for open closed contacts .. all ok. Note - passenger side window works perfect.
When I changed the window motor, there are 2 coloured wires that go to a plastic connector block. 2 black wires also to connect. Can anybody tell me what the correct wiring is to the 2 screw conn, or how to check it is correct?? Wiring diagram would be great.
And if it helps anyone in the future... do not attempt to remove the door lock/latch assembly unless you really have to.. its a bitch!!!
Many thanks
