- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, ML63, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
The SLK 55 spat its serpentine belt off today - the tensioner pulley seized. No noises, just the red battery/alternator warning, then about half a mile later the power steering became manual steering. Fortunately, I was only about a mile from home, so throttled off and used minimal throttle until I got there. The engine temperature rose no more than 10 degrees, so no other harm done, and the serpentine belt is fine too.
I'm pretty sure this:
Febi Tensioner Pulley V-Ribbed Belt 45875 - GENUINE - 5 YEAR WARRANTY | eBay
is the correct Febi pulley, as confirmed by their online catalogue. It's actually described as an 'idler pulley', though they also list another idler pulley which is identical to the idler pulley on my car; I think something has been lost in translation, because the website states: "The idler pulleys guide and hold the auxiliary belt in its entangled position..."
The seized tensioner pulley is a smaller-diameter all-metal item, with a lip on the side away from the engine, but this one is larger and has no lip. I've seen mention on one of the US websites (I think) that there are two versions, and that the later one (I presume this Febi item) will fit and do the job.
Can anybody confirm this?
