Radio interference when using the 12v socket
timwood2000
Bromley, Kent
R320 CDI SE LWB '07, BENTLEY CONTINENTAL FLYING SPUR MULLINER '06, FIAT 500 LOUNGE '58 & BMW R1200RT
My car has just been in as the a/c system failed due to blocked channels causing water to get into the electrics of the system (I think) and looks like they had quite a bit of a job to sort it out, pulling half the passenger side dash out etc.
Anyway, since I have had it back, when I use the 12v socket, I get mild interference on the radio - is there an obvious answer to why this is happening or is it a mystery problem that I should learn to live with?
Good question!
No - it didn't
Where was the car repaired as i would take it back to them and explain to them that the problem was never there before.
Also if there was water getting to heating/ac i expect water to have gone into the electrics below the floor as the r class has a false floor in it which covers all the control units up so one of them may have water in it still
The most likely fault is a poorly remade earth connection when they were putting it back together.
RF interference is generally due to poor grounding....my two pence worth...I am a qualified heavy power electrical engineer although sometime I doubt myself!
Ask me a question about generating a couple of hundred mega watts of power on an offshore installation and I'm your man :-) or maybe I should stick to flying!!
Poor earthing gets my vote!
As said, if it didnt do it before, take it back to where the repair was carried out.
