rattling supercharger w210 query
brens-e200
naas, ireland
1990 230E W124, 1992 C124 220E
hi all
i have a 2002 w210 2.0 Kompressor and the kompressor rattles. Its not too bad but noticeabe ( well to me anyway ha ha ) and has 140k on the clock. There doesnt appear to be any performance impact as it still accelerates well
I was wondering
1. where is the part number located on the unit so i can seek a replacement
2. If I go down the second hand unit path what do i need to check ?
3. is there any risk of letting it continue to run as is
4. any advantage in getting a larger unit or one from a different model ?
thanks in advance
brendan
Are you sure its the charger?
The camshaft advance mechanism tend to rattle when worn.
If you can get hold of a mechanics stethoscope, do so.
Otherwise, while exercising great caution use a screw driver instead. Metal tip on item, handle in ear should allow you to have a listen and track down the noise.
thanks
hi Amin
i used the screwdriver method in narrowing down the source .
regards
brendan
Its at the end of the camshaft under a small cover. Just unplug it. If it goes away the its that.
