Hi Rorf,So why didn't you just go out and buy a second hand engine - and you have still not said what the original problem was.
Expect to pay for high quality professional work.
First off this has never been about the cost. I picked this option because as you say, I expected to pay for high quality work. I came on here originally because I was questioning the quality of what had been done.
Regarding a second hand engine, I was offered a couple at around £1500. They had around 49k miles on them, which I was happy with, but none of the sellers were willing to verify the mileage. As they were out of insurance write off's I asked for the vehicle reg no's so that I could maybe check the MOT history on line and verify the mileage that way. I was told that this information could not be released. I'm not fitting the engine myself as I don't have the kit or facilities so I'm having to pay someone to do the work. Nightmare scenario therefore is to by a second hand engine with unverified mileage and ending up with a crock and having to repeat the exercise.
So I decided to bite the bullet and have mine remanufactured.
Sorry, This is turning into war a peace.
So what originally went wrong?
I was coming out of a T junction in 3rd, but was going to slow so dropped into second. The car made a noise as if I had changed gear without the clutch, severe loss of power and rough running. I was very close to home so I limped back and the engine was sounding very rough. I called out a mobile mechanic who initially found a split in the hose that connects to the inlet manifold. He thought initially that this was the problem, but ran a diagnostic check and found that no4 cyl injector was out of limits. So we replaced the hose and the injector and he took it for a run, but aborted that as from the noise he could hear from the bottom end he was worried he might put a rod through the block! I suppose I could have gone further into diagnosis, had the sump off (not easy from what I understand) but just decided to bite the bullet and have the engine fully sorted.
Since having the engine out, I have been cleaning up all of the ancillaries and what I have found is that on no 1 cyl, the inlet ports on the head, the manifold and plenum chamber at the intake end are all thick with black gunge. Not sure what that is about or why only on that cylinder, unless I had a valve problem???
