brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Folks.
On my W203 C55 estate the rear wheels are not central on the car. This is evident as the rear N/S sits inside the arch 10mm more than the rear O/S. This is visibly noticeable when looking at the car. I also have a C240 estate and it does not have this issue.
To date I have had the following done with no change.
Full geometry check at WIM
New rear subframe and suspension arms. While the subframe was off the car was checked for any signs of damage on the mounting points or floor pan (no damage found)
Full geometry check (2nd time) with new sub-frame.
Chassis alignment check.
If you measure from the top of the inside wheel rim to the shock the gap is 10mm less on the N/S than it is on the O/S. This says to me that the subframe needs to move over towards the N/S as that would push that wheel away from the shock. However there is no adjustment in the subframe that allows this.
The bodywork appears to be true with no bad panel gaps or creases.
Any clues?
Any clues?
