I might need to remove the RVM to finally get at the cabin temperature sensor to clean it out. THing is for a long while I have noticed the RVM has slight annoying vibrations when the car is on the road. Will removing the RVM make it worse? If I do remove it, anyone had this vibrating problem enough to have fixed it - how? Any suggestions to make it more solid? What is likely the cause of vibration? Mirror or base?
