rear window defroster w202
lars-mad
nearby Oslo in Norway
1996 c180 2.0 1995 C180 AMG 1988 190e 2.3 1989 230CE with facelift
hello got a problem with the clima control i think it is manual the fan goes on different speeds and if i give the panel a light knock it changes speed
also the defroster is not working when i push the button it lights up and turn off after a few minutes but the window is still icy so i think there must be a problem with the clima panel.. it got nr 210 830 20 85 if i remember right and that is a realy expensive part over here is there posible to open the panel and fix ? anyone
Sounds vaguely similar to what I had recently. I took the panel out cleaned the contacts and squirted compressed air and hey presto! air at the right speed.
There's a thread somewhere.
thanks :) will try find the thread
Lars
solved had to open the combi relay and resolder all the contact points and now everything is working 100%
Got c180 W202 and rear defroster light on switch not coming on have checked fuse it’s ok . Does anyone have some ideas please
