Yes, this might be it, thanks.HERE YOU GO http://www.w124performance.com/service/w124CD1/Program/Engine/104/18-1000.pdf
Looks as if there might be an oil thermostat involved?
Very good info, thanks! So, i need a thermostat to be able to warm up the oil? With the M103 oil filter housing, that is.It looks to me as if the thermostat in the M104 is designed to by pass the built in heat exchanger [ people misunderstand this unit- its as much about heating up the oil as cooling it] There doesn't appear to be one at all in the M103 unit. The M103 unit shown in the diagram doesn't have the take off points for the remote air cooler you have which is in this instance a true cooler not a " warmer upper"
Does anybody have an idea how to pull out the non return valve/thermostat from M104 oil filter housing. I would put it in the M103 housing. The size is measured to be the same.
I decided to leave the non return valve out. Function of it is to avoid the oil filter to drain and dry while stand still. In my relocation setup the filter is upside down, so the is no need for a non return valve.Does anybody have an idea how to pull out the non return valve/thermostat from M104 oil filter housing. I would put it in the M103 housing. The size is measured to be the same.
Would somewhere along the oil lines for this install be a good place to attach a pressure sender for an oil pressure gauge? I've used the standard pressure test port on an M113 before but adding one in between the block and the remote filter would be much easier if already doing this install
