Retrofit Sat/Nav or Command
mercman1969
Have recently purchased a 52 plate 320 ML with lpg conversion
Car has everything we need except sat nav or command
How easy if at all is it to retrofit this package?
Regards
Pete
Regards
Pete
Have you done any searches on this because there are loads of posts on the internet about Comand retrofits?
I would suggest you search first then come back with specific questions. BTW make sure you search for "Comand" (this is the correct spelling) and "Command" as posts appear under both spellings.
Regards
Pete
Easy Peasy lemon squeezy;) 30 minutes tops:rolleyes:
LOL for you maybe, for the rest of us mortals, perhaps a bit longer:D :) :D
Thanks all who have taken the time to reply
Alfie, Surely it is not that easy 30mins?
What is required, can you supply it and at what total cost including fitting?
Cheers
Pete
