Rhapsody digital phone system inc handsets
bolide
Brighton
BMW E39 525 Diesel Touring
This is the phone system I had in my old office. BT Rhapsody, 4 lines, 8 extensions. The system comprises:
* wall-mounted PBX unit (34 x 26 x 45 cm)
* eight handsets
* 19" 1U patchpanel
* wallboxes (enough for the system)
This will be ideal for a small office or a big house. You can call, and transfer calls, between extensions. All extensions can pick up any outside line to receive or make calls. Ideal if you have more than one line on one number. From memory the PBX has an analog card for a fax line
Pretty easy DIY installation or I can put you in contact with a chap who can install wallboxes & commission the system
Small PBX systems are cheap now but this is a slightly larger system than most out there. I bought this refurbished and used it for two years
Cheap as chips: £120, come & collect or send a courier to Brighton BN1
Nick Froome
