3 phase
I have posted about this before but the problem has returned.
I have a cold to warm rough idle problem that disappears once the engine is hot. The rough idling feels like it's only running on 4 or 5 pots. Once above 1000 rpm it's smooth running on all 6 and pulls as well as a 300 non turbo will pull.
Over the past year I have replaced all the plastic pipes and viton rings, the delivery valves were leaking 6 months ago and they have been renewed. There are no diesel leaks and no visible signs of air bubbles in the lines. Fuel filters are new.
When the engine is hot it is smooth and running fine, but once the temp falls back to below 40 to 50C after being parked then the rough idle commences but ceases when it's hot again.
I wonder whether this can be caused by any of the vacuum operated valves on the inlet side, are these actuated at higher temperatures or could it be EGR related, the EGR is standard and connected as normal. Can anyone tell me what the valves on the inlet manifold actually do, and I honestly don't know what the heat exchanger does on the IP either.
Thanks in advance for any advice.
