Hi All,
56 plate CLK run flat indicator reset. I had a rim refurbed on the car before I collected it so they obviously had the tyre off the rim to do that. 100 yards down the road the run flat indicator reset warning came up. I have read the replies on here with someone with a similar problem but when I scroll through the menu options with the arrows on the steering wheel I don't get the tyre pressure option. I am awaiting the ops manual from the supplying dealer but just wondered if anyone could help me sort it now? If I hold down the reset button at the side of the dash it says it will reset everything to factory defaults which may cause more headaches than it fixes? Hope someone can help. Cheers.
