Run flats
A250 Bennyboy
Northwest UK
A Class A250 w176
I have recently bought an A Class A250 w176 and it had run flat continentals fitted.
Do not like these tyres at all, thinking of changing them to Goodyear eagle F1s normal tyre,
Do you think this would also make any difference to the ride, ie less harsh
I find one other draw back with run flats is they increase the stiffness of the ride, plus road noise is awful.
How does anybody else feel about run flats? Would you refit them?
Cheers :thumb:
Check you have a spare, or at least tyre repair gel etc, if you do ditch the run-flats.
If the run-flats are OEM, check with your insurer before going with 'normal' tyres
Thanks for advice, yeah I would have to get myself and jack a can of jollop and a compressor, only things I have in the boot space is a triangle and locking nut.
Never thought of checking with insurer, I'll give them a ring when tyres are ready to be replaced cheers
