Russian Site and the other one
What i am having , is that the laptop turns on , and is fine until you get to the black screen with 'Windows XP' on it with a little box with three blue blocks that scroll across ...
It just hangs on that part , won't go further , the drive stops spinning and that's it ...
Won't start in safe mode either , just hangs on the XP screen ....
:mad:
Occasionally when i turn it back off after this has happened , when i turn it back on , it goes to a blue screen and says it is checking the disk.
At least the disk is partially working. I suspect most of the data is recoverable by attaching the drive as a slave. If a chkdisk doesnt fix it enough to boot then you'll be needing to do a reinstall of windows onto the new disk though I suspect.
Thats exactly how mine died. Now, this is what I did (It's common practice for drives actually):
Stick the drive in an air tight bag, and suck all the air out. Put it in the freezer overnight. Take it out the next morning and plug it in - it "may" boot up just fine, and this will give you 10 - 20 mins to grab files and move them over to the new drive.
The freeze of the drive helps re-align the arms the read the platters on the hard drive temporarily as the cold contracts them.
It doesnt alwyas work, but if you cant use it anyway, its worth a shot!
ONLY DO THIS AS A LAST RESORT IF THE DRIVE WONT WORK AFTER REINSTALL / CHKDISK ETC - IT CAN DAMAGE THE DISK LONG TERM - I ONLY DO THIS IF IM ABOUT TO THROW THE DRIVE OUT
I'll try it tomorrow .... I suspect my bout of 'percussive maintenance' :rolleyes: after it wouldn't work for the umpteenth time may have done for it though ....
I've got the recovery disks and all the driver disks , how difficult is it to re-install windows and all the drivers ?
Could a plum like me do it ?
If you have a recovery disk it will be easier than normal as they are designed for non computer users - normally you just stick it in and reboot, click ok a few times and it will do the rest.
So , bung a brand new HD into the laptop ...
Stick the CD in and away you go ?
Sorry to drag this up again , trying to retrieve links again ...
Anyone got the link to the DVLA site to lookup the details
As always fellas , many thanks .
New hard drive is working a treat ! :bannana:
