I rather doubt that; can you quote the reference to support it, please?Unfortunately not - it's technically illegal to have a towbar fitted to the car at all.
The main requirements of an EC Approved towing bracket are that it is fitted to all of the towbar mounting points specified by the vehicle manufacturer,
If your car is registered on or after 1st August 1998 and you fit a towbar, it MUST by law be approved to EC94/20 and installed correctly according to the manufacturers' instructions. It is an offence under the vehicle Construction & Use Regulations to fit, use or permit to be used, a non-approved towbar on the vehicle
Tow Bar Legality on Non Type Approved Vehicles
Thank you for your email dated 14 March to the Department for Transport about tow bar Legality on Non Type Approved Vehicles. Your correspondence has been passed to us in International Vehicle Standards (IVS) as we have responsibility for vehicle safety.
We suggest you contact the manufacturer on this matter as there may not be any points of sufficient strength to mount the towbar.
Assuming it can be safely mounted, we believe that you could use a towbar mounted bike carrier.
Please note that this letter contains the views of the Department for Transport and that insofar as this letter provides an interpretation of the law, it is only a court of law that is able to give a legally definitive interpretation.
Yours sincerely
Where does that leave me?Many towbar sites have text similar to this (from towsure.com) ... it's the best I can do for now:
If a car isn't type-approved for towing there are no manufacturer specifications for fitting a towbar, so you can't comply with these requirements.
American import registered in the UK in 2002. I didn't fit its (non EU approved) tow bar (that was done before it left the factory), and don't use it or permit another to use it (it requires a detachable ball I don't have). Is its mere presence in contravention of the vehicle Construction & Use Regulations?
And, if I wanted to tow, I have the option of mounting a ball directly into the bumper. If I fitted an EU approved ball (if such a thing exists) would that be legal as no tow bar is required?
Better than nowt, especially in my R129which is not a lot.
Irs for transporting a 200kg PA system so will be fineOnly a 750kg towing limit though......For those that don't know its the gross train weight (max weight of car added to max weight of trailer) so 3245kg in this case, minus the max loaded weight of the car.....2495kg in this case....giving you 750kg....which is not a lot.
By the way,
Attached is the correct wiring for a 2003 S211 Tow bar wiring with bypass relay.
There are endless amounts of incorrect information online!
My S211 Tow Bar wiring now works properly - For only £35!
