franey
Hi.
S320 cdi not starting. Had new injector seals, new alternator, new turbocharger and mechanical fuel pump.
Diagnostics point to the fuel pressure switch at the rear end of the common rail.
However, mercedes now state that you cannot buy this part £250 and must buy the complete rail with sender and switch attached. Car refuses to start.
Anyone had similar problems?
A Bosch equivalent is available (only the switch) from the Fatherland somewhat cheaper.
If you had this problem, did replacing the switch cure it?
Cheers.
Sorry on wrong section, OOPS!! help.
Cheers.
