Sat Nav, Command
MercE350
Scotland
E350 CDI, Sport (265), 125 edt.
Hi, is there an option to turn on or update for the Sat Nav that shows POI, namely static speed camera's, my niece has a Nissan Juke with built in Sat Nav that bleeps when approaching camera's and it dosen't need to be in use, bleeps over radio.
Depends on what COMAND you have. If you have one that you can import POI from SD card, then there are databases available you can import and make the COMAND ping.
Richard
Richard
I have a 2012 C350 sedan. I only see visual indicator option. Will a COMAND firmware allow audible indicator?
I have speed camera alerts on an sd card on my command ntg 4.5, it gives visual and audible alerts .
Is the option for audible alerts visible in the navigation settings? I only see visual alerts on mine.
The option comes up automatically after downloading POI from sd card onto command .
thanks for your replies, i will give this a try with the SD card
